Garyblue Posted Wednesday at 03:30 PM Posted Wednesday at 03:30 PM (edited) Just acquired a 2012 2.0 td with stronic automatic gearbox. Runs great BUT after about 10 miles at 60-70 mph there is a shudder from the front passenger side. If I slow to 50 it stops but comes back at 60. Then, when I brake it shudders. The odd thing is these symptoms never appear at any other time, only on a run. Mileage is 77,000, I have fhs and gearbox last had an recent oil service 51,000 miles. Im thinking bearing, or brakes. Would appreciate opinions. Edited Wednesday at 03:50 PM by Garyblue Update
cliffcoggin Posted Wednesday at 05:33 PM Posted Wednesday at 05:33 PM Have you eliminated wheel balance and tyre wear as a first step? If so, I agree bearings or brakes are most likely, but don't dismiss CV, steering, and suspension joints as possible causes.
Garyblue Posted Wednesday at 06:03 PM Author Posted Wednesday at 06:03 PM At someone's suggestion, I felt the disc, it was hot compared to the other side. I suspect caliper or bearing, will get it checked.
