JDL Posted February 28 Posted February 28 Hi so this is my first post here, I bought an A3 8P a couple of days ago, and I've discovered a quirk of my car, the radio intermittently turns off (black screen) and then upon pushing the mute button turns back on. it's weird because there are times it's fine and will stay on continuously throughout my drive, and then there are times where it's every other moment it's off again. I can't tell what causes it but from my experience so far the position of the volume dial affects whether it goes off or not, there's a region where it's bad and then a region where it's somewhat better. Opening the card holder has also caused it to turn off any ideas as to what the issue is? thanks
Steve Q Posted March 1 Posted March 1 I'd recommend checking the wiring but I'd bet it's an issue with the radio itself. Cheapest option would be to replace the head unit with. Second hand one from eBay. You'll need the radio code for the replacement unit.
JDL Posted March 2 Author Posted March 2 On 3/1/2025 at 9:29 PM, Steve Q said: I'd recommend checking the wiring but I'd bet it's an issue with the radio itself. Cheapest option would be to replace the head unit with. Second hand one from eBay. You'll need the radio code for the replacement unit. I'll hopefully get a look at wiring tomorrow, and then If it isn't that which it probably isn't I think a new radio is the best course of action, will keep you updated thanks
