8VA3 Posted 20 hours ago Posted 20 hours ago Decided to upgrade my headlight bulbs and after doing so my side lights no longer work, when switched to the side lights option they come on but switch back off again. Also the headlights are not adjusting using the dial and doing it manually made very little difference, when trying to get to the bulb accidentally removed the adjuster beside the bulb. Does anyone have any info on a fix please?
8VA3 Posted 19 hours ago Author Posted 19 hours ago 8 minutes ago, 8VA3 said: Decided to upgrade my headlight bulbs and after doing so my side lights no longer work, when switched to the side lights option they come on but switch back off again. Also the headlights are not adjusting using the dial and doing it manually made very little difference, when trying to get to the bulb accidentally removed the adjuster beside the bulb. Does anyone have any info on a fix please? Didn’t put LEDs or Xenons in just swapped to halogen Osram nightbreakers
