Hi all I have an Audi q7 2018 model. Whilst Audi had the vehicle due to a knocking noise found it was driveshaft 馃槖. They also did a health check and found the bushes will need replacing soon, however they pulled my pants down on the price. Now it seems tricky but I would like to put uprated bushes for this particular vehicle but I cannot find the right bushes for the front end. Even if I can鈥檛 go down that route what鈥檚 the best place to get a blueprint? And potentially someone up north west direction that is happy to tackle doing the bushes 馃槄
Audi will charge you north of 拢180 a hour. Suspension, you鈥檙e probably talking minimum of 6 hours. Which bushes are you talking about? I鈥檇 be wary of sticking on things like Powerflex or similar and change the ride completely.
Assuming it鈥檚 lower arms or even upper arms, then Meyle HD or Lemforder. Parts will be expensive, but it is what it is. After work is done you鈥檒l need a tracking alignment check.
See parts diagrams on LLL Parts here (double check against engine code):聽https://www.lllparts.co.uk/catalogs/audi/RDW/AQ7/859/4/407/407000
Most independent garages won鈥檛 fit if you buy parts, but will order on your behalf.
Can鈥檛 help on garage on North West. I follow Decimal Tenths (North East), and seem dedicated.
