shaza Posted March 5 Posted March 5 Hello can somebody please help. I would greatly appreciate it. When I drive my Audi A3 at exact 60 mph, I hear a buzzing noise coming from the engine. The noise is to the effect of a mobile phone vibrating when on silent and lost behind a sofa.. The buzz PXL_20250305_125204760.mp4 The buzzing starts stops, then starts for a little longer and then stops, at various lengths of time. It only happens at 60 mph, not at any higher speed or any less speed which makes it really bizarre. I have recently tracked the car and wheel balanced it. Changed all 4 tyres. Its definitely a noise coming from the engine area from the drivers side. I have attached a video of the noise so you can hear it. If you listen carefully and ignore the typical road noise, you can hear it Any help would be really appreciated. Thank you
cliffcoggin Posted March 6 Posted March 6 Sorry Shaz, but as usual with audio recordings it is impossible to hear anything unusual. If the noise started after new tyres were fitted it may simply be they are generally noisier than the previous tyres, however it would not hurt to have them balanced again. It is not unknown for new balance weights to fly off.
