mike blair Posted 22 hours ago Posted 22 hours ago Hi I am totally ignorant of all things SD - don't have a clue - any advice appreciated - can I play music from SD card? - if so,what type of card will I purchase and do I require an adapter?
cliffcoggin Posted 20 hours ago Posted 20 hours ago Michael. You can certainly record music onto SD cards, but you need to record it in a format that the car is capable of playing. There are numerous formats such as mp3, wav, ogg for examples so you need to find what format your car needs. If your car does not have an SD card slot then you will need an adaptor to plug into whatever input socket is available. If the car has a USB socket consider using USB sticks instead of SD cards, though the same considerations of formatting must be applied. There are many classes of SD card which are categorised on data transfer speed and capacity. I think even a low speed card will be sufficient for music, though it is always worth getting something better than the bare minimum. https://www.kingston.com/unitedkingdom/en/blog/personal-storage/memory-card-speed-classes The subject is really too big to cover here so do some research or consult a car audio specialist.
mike blair Posted 19 hours ago Author Posted 19 hours ago Hi Many thanks for prompt reply - my A1 has 2 card slots with one holding SatNav card - will purchase Kingston 32GB Micro SD Card SDHC SDXC Memory Card TF Class 10 32GB SD Adapter UK and give it a try - it's only £5.99 Many thanks again Mike
