Ish91 Posted 11 hours ago Posted 11 hours ago (edited) Hi, I have a 2023 Audi A5 2.0 TFSI. I had 2 questions. 1 - when I try to get my Oil reading on the MMI, it shows the below. However even after keeping the car on for over 5 minutes, the bar doesn’t change.. it’s gone from OK to Ideal - so I was expecting the bar to reduce? 2 - When I drive my car, whether it’s a short distance or a long distance, the engine cooling fan turns on once after every journey. It stays on for exactly 5 minutes after I’ve switched the car off, and then turns off. Is this expected? Thanks in advance ! Edited 11 hours ago by Ish91 Added info
cliffcoggin Posted 7 hours ago Posted 7 hours ago 1/ Electronic oil level sensors are none too reliable. I believe they are easy to renew. 2/ Yes it is normal for the fan to run for a few minutes, though I forget the reason why.
