RMB UK Posted March 13 Posted March 13 Hi. Has anyone had issues with the AUDIUTR hotspot password? The default password does not satisfy the system's own minimum criteria "Too weak", and cannot be saved. My AUDIUTR app still has that default password and cannot connect to the dashcam system. From what I understand the only way to resolve this is to do a factory reset of the camera system, but, following the UTR 2.0 handbook instructions, after holding the power button for 20+ seconds there are 3 "beeps" and the system closes down. Unfortunately though, when it restarts, it has not reset the password to the default and hence I cannot connect my app to it. I thought about getting a replacement SD card from Audi, but from what I understand the password is not stored on the SD card. Has anyone actually managed to successfully resolve this issue? TIA.
Steviewii Posted March 14 Posted March 14 Hi Richard I have the same problem, cannot get it linked to my iphone, keeps going around in circles. I did manage to get it connected to my Ipad though. If you have another device it might be worth trying that. I haven't managed to transfer it from my ipad yet and it doing so I cannot now get back into the ipad. If you do find a solution please post it here
RMBMS Posted March 19 Posted March 19 How did you manage to connect to the iPad if the password is different to the one on the UTR?
Steviewii Posted March 19 Posted March 19 With the Ipad it just followed what I assume is the normal procedure, it firt connected to AUDIUTR and then forced me to create my own ssid and password. It is still working in the Ipad but still haven't managed to get it on the phone yet. I reset everything, started again with the phone but same issue then tried the ipad, and it went through first time forcing me to create another new ssid and password.
RMBMS Posted March 20 Posted March 20 On 3/14/2025 at 2:51 PM, Steviewii said: Hi Richard I have the same problem, cannot get it linked to my iphone, keeps going around in circles. I did manage to get it connected to my Ipad though. If you have another device it might be worth trying that. I haven't managed to transfer it from my ipad yet and it doing so I cannot now get back into the ipad. If you do find a solution please post it here Today Audi changed the camera unit in my UTR system, but after then loading the hotspot settings the AUDIUTR password that I had previously set was still there. I can therefore only assume that the password is held somewhere other than in the camera itself.
Steviewii Posted March 21 Posted March 21 I read on other forums that the password file is saved on the SD card, however, I couldn't find it when I took the card out and examined all the files on it
