daveyboy1967 Posted 14 hours ago Posted 14 hours ago Just thought I'd share this link for replacing the window regulator in an A6 C5 as it's the most helpful one I've found. Very clear instructions and tells you which Torx bits and rivets you'll need. The whole process took me about two hours start to finish and I was taking my time to ensure everything was correct. Hope this helps anyone contemplating the same repair. How To: Replacing AUDI C5 RS6 Window Regulator! 1
