Rizwan Patel Posted 7 hours ago Posted 7 hours ago So another DIY job been putting it off since we got car. The cd player is messed up. Want to get replacement off eBay. Two silly questions 1.if part number is same then is it simply plug and play or would it require coding 2.currently car has sensors no reversing camera. If installed one could it be a OEM style where it works on screen when selecting reverse. If so is there hardware wire ports ect on existing unit or would additional hardware be required And as above would a camera need to be installed also please see attached link seen this so wondered is is a easier option https://a.aliexpress.com/_EIBLyhq Once again thanks in advance
