Rizwan Patel Posted March 18 Posted March 18 So another DIY job been putting it off since we got car. The cd player is messed up. Want to get replacement off eBay. Two silly questions 1.if part number is same then is it simply plug and play or would it require coding 2.currently car has sensors no reversing camera. If installed one could it be a OEM style where it works on screen when selecting reverse. If so is there hardware wire ports ect on existing unit or would additional hardware be required And as above would a camera need to be installed also please see attached link seen this so wondered is is a easier option https://a.aliexpress.com/_EIBLyhq Once again thanks in advance
Steve Q Posted March 18 Posted March 18 Yep same part number cd player shouldn't need coding. Regarding the camera id recommend you speak to auto retrofits or autologics about what's involved.
Tigger Posted March 24 Posted March 24 I was under the impression, due to thefts and the illicit market in stolen/stripped cars and subsequent spare parts, that things like the CD Player and other infotainment components, amongst others, were coded to the VIN of the originating vehicle? If so then they would need to have the vehicle identity changed before they work in a new, or different, vehicle? I may very well be wrong, but this is what I was told when earlier looking for a component (it eventually turned out I did not need). I hope that makes sense, and I'm sorry I cannot answer definitively. Cheers, Tigger
