DCQUOTTRO Posted 15 hours ago Posted 15 hours ago I need to source a replacement starter motor for my 2012 mk 11 TT Quattro TDI. The present unit is a VALEO one with a part no. 02M 911 024N with an 11 tooth pinion. A replacement VALEO unit from a reputable supplier has 12 teeth and they assure me this will fit and operate satisfactorily. My elementary gearing knowledge says this wont work. Has anyone experience of this or an opinion? David.
cliffcoggin Posted 13 hours ago Posted 13 hours ago I agree that a 12 tooth pinion would have 11/12ths of the mechanical advantage of an 11 tooth pinion if all other factors are the same, so does the replacement motor have increased torque to compensate?
DCQUOTTRO Posted 3 hours ago Author Posted 3 hours ago Until I receive the replacment I dont know its power output, hopefully there will be literature with it. Also the old starter lists a number of power outputs under that part no. All very confusing.
cliffcoggin Posted 39 minutes ago Posted 39 minutes ago I can't help on that score. Do please let us know the outcome.
