I've found a video on removing the tailgate light where the lock barrel is housed. I'm looking at just replacing it but will any lock barrel work for the a4 or do I need a new key blade?
Wd40 hasn't budged it. Totally seized. Hammered it with a socket. Pushed a screw driver in. It's totally knackered.
Posted (edited)
2 minutes ago, cliffcoggin said:
Is thus the same boot on the same car that you reported as fixed an hour ago?
https://www.audiownersclub.com/forums/topic/28341-a4-cab-issues/
Different one mate. 😂 fixed the last convertible and now having a go on the second. The lock cylinder isn't related to the last one.
Going to be a pig. The rear window needs regluing, the f294 microswitch likely needs replacing and a few other niggling issues.
Edited by Jamiem93
