Megabart Posted March 21 Posted March 21 Hello guys. I have problem with auto cruise control unit. It intermittently stop working and now completely died. I found that 1 of the pins were corroded and felt off. I almost sure that this is the problem and if I replace it will go back to life. I have a problem to find replacement as the part number is unreadable. Can anybody tell me the part number or where to buy. I only need that little port. Thanks in advance
Stevey Y Posted March 21 Posted March 21 3 hours ago, Megabart said: Hello guys. I have problem with auto cruise control unit. It intermittently stop working and now completely died. I found that 1 of the pins were corroded and felt off. I almost sure that this is the problem and if I replace it will go back to life. I have a problem to find replacement as the part number is unreadable. Can anybody tell me the part number or where to buy. I only need that little port. Thanks in advance Hi go on LLL carparts online and put in your VIN number, its an online parts store that should give you an exploded diagram with the part number, judging by the last picture I think it will probably be sold as a whole unit in which case you might be better served going second hand the whole unit number is under the Bosch logo in the last picture looks like 561 b?. Steve.
Megabart Posted March 21 Author Posted March 21 (edited) Thanks Steve for your respond. It's 561A whatever in means. I wanted to replace the whole thing from the beginning but when I opened it I think I found the main failure and I'm hoping to fix this proplem cheap. The unit itself is minimum 400£ second hand so probably won't last long. Maybe it will be my way to fix it but if I had a chance to buy that little bugger I think it would be really cheap fix. Edited March 21 by Megabart
