Hi,
My DRL/sidelights gradually stopped working (2016 facelift S-line A3) - they were on and off for a bit, but eventually one gave up, then the other. I removed the DRL/indicator units from the headlights and saw both had burnt out the DRL LEDs, so I bought replacement units. I have fitted them, but neither work - I still get error codes that they aren't working (DTC 567062 and 567318), but the indicator LEDs still work. Is there a fuse specifically for the DRLs? I haven't found one and all my fuses seem fine. I was lead to believe they don't need any coding, they are just plug and play. Do they need some kind of resetting by VCDS?
Thanks.
If both have burnt out I'd recommend getting the car checked by an auto electrician to make sure the wiring is ok. I don't believe they need coding
