Hi all,
Not had this long, My mrs tried to open the front passenger window from the passenger side the other night & it wouldn't work from her side, but would work fine if I used the switch from the drivers side?
I have also noticed its not glowing if I drive in the dark so I think the wire plug may have come of or a dead switch?
I have not looked yet but might do if I get chance over the weekend , it the undernether of the stich easy to get to ? workout?
I have take other cars doors apart in the past so have a vague Idea so planing ahead this time
Ben
sounds like the connector has come out, maybe it has been disconnected before and not put back properly and has come loose
Thanks Steve,
Thats what I am hoping it is ,
It is easy to get the switch out to check ?
I have taken my old Alfa GTV door apart many times as well as replacing a mk3 golf window motor in the past so should be able to work it out, anything I need to be careful / aware of please?
Ben
I think Steve has the problem down. That's my first thought anyway because it there were another problem then I doubt your switch would work.
Glen.
HI All,
Great, sounds like it could be a cheap fix then, has anyone got any instructions to getting to the bottom of the swtich? do does it just prise up with a flat head screwdriver for example .... carefully!
Thanks
Ben
