ETHel Posted March 30 Posted March 30 I need to take the steering wheel off my car so airbag disconnect. I read that throttle learning will or may need to be done afterwards. What are your thoughts please....
Stevey Y Posted March 30 Posted March 30 3 hours ago, ETHel said: I need to take the steering wheel off my car so airbag disconnect. I read that throttle learning will or may need to be done afterwards. What are your thoughts please.... Hi I can't see that one myself as you would have to do that every time you changed the battery as far as I know the throttle data is stored in the ECU and only changes when you fit a new throttle valve therefore the values have to be reset as the new one will move the butterfly a lot more easily than the old clogged unit. Steve. Quote
ETHel Posted March 31 Author Posted March 31 Thank you Steve, your answer much appreciated. Not had the car long, I was had.....loads of problems and bad repairs! But I am getting through them, slowly. 1
