joeblo Posted April 1 Posted April 1 Hoping for some help with my B7 avant 2007 2.0 tdi 140 My airbag light is on & code: 01217 side airbag ignighter drivers side (n129) upper limit reached Has shown on scan. I've read its usually the seat but the seat connector has been bypassed & there's a resistor wired in there (previous keeper) I've stripped the door pillar looking for the side airbag igniter but it's not there does anyone have ant idea where it could be? Thanks all聽
Stevey Y Posted April 1 Posted April 1 2 hours ago, joeblo said: Hoping for some help with my B7 avant 2007 2.0 tdi 140 My airbag light is on & code: 01217 side airbag ignighter drivers side (n129) upper limit reached Has shown on scan. I've read its usually the seat but the seat connector has been bypassed & there's a resistor wired in there (previous keeper) I've stripped the door pillar looking for the side airbag igniter but it's not there does anyone have ant idea where it could be? Thanks all聽 Hi its most likely the resistor that is the problem, most idiots put these things in rather than repair the offending module, this just leads to problems as when the resistor fails [chinese cr@p] it throws the whole baby out with the bath water, I think you will find the igniter is integrated in to the end of the airbag, the tragic consequences of such bodges is the airbags fail to deploy in a collision and just promote more serious injury, best policy is to engage an auto electrician which may engender some new parts as well. Steve.
cliffcoggin Posted April 1 Posted April 1 2 hours ago, Stevey Y said: 聽most idiots put these things in rather than repair the offending module, <SNIPPED>, the tragic consequences of such bodges is the airbags fail to deploy in a collision聽 Whoever does that clearly values his wallet聽 more than his life. I nominate him for a Darwin award. 1
