Marcin Z Posted April 5 Posted April 5 Hello, There is a drain located below the fuel cap. It is visible when you open fuel flap and is just at the bottom of the rubber collar that sits kind of under/around fuel filling "pipe". Mine is blocked and water is collecting in the space under the fuel flap. Does anybody know where this drain comes out under the car? I have tried pushing a flexible wire through it from the top to unblock it, but was not very successful although I was able to push quite a bit of the wire through. I thought I could maybe tackle it from the bottom end if anybody knows where it comes out.
Marcin Z Posted April 8 Author Posted April 8 On 4/5/2025 at 9:10 PM, cliffcoggin said: Perhaps try sucking from the top end. I don't have anything to suck it with. I think I'll just keep trying to push the wire through from the top and see how it goes. I was also thinking if I could try and blow some compressed air through it, but not sure if this could cause any damage or not.
Magnet Posted April 9 Posted April 9 Compressed air at around 30psi should sort it. Kind regards, Gareth. 1
cliffcoggin Posted April 9 Posted April 9 Yes, I favour compressed air over wire. If the drain tube is plastic it could be pierced by wire at a bend.
Marcin Z Posted April 18 Author Posted April 18 Thank you for your replies and suggestions. In the end a lot more persistence and a different flexible wire has sorted out the issue.
