Hi! I had a very small run in with a tow bar and have damaged the front grille on my 2021 A4 Avant Black Edition. It's the honeycomb style one as part of the b9.5 facelift, i think.
Photo attached, damage not really visible but if you look at the image it's to the bottom left of the plate.
Will erWin give me the info i need, i don't mind buying a couple of course to download as much as i can but thought i'd check first.
Thanks in advance!
D
Hello Davie,
erWin?
Although  a main dealer part, we take it you don’t want to buy from Audi-?
Regards,
On 4/12/2025 at 9:21 AM, Magnet said:
Hello Davie,
erWin?
Regards,
Hi Gareth, thanks for the reply and sorry for lateness getting back to you.
By erWin i mean this site: https://audi.erwin-store.com/erwin/showHome.do
I can pay a nominal amount (i think it's something like £8) for an hour then go get the info i need. I think this is more for repair manuals though than part ID but if i have understood i can get the part ID's from that then go and buy it.
I am open to buying it from wherever i can really? I have found a few on eBay / <insert random site here> but when going into more detail the quality of the parts or the supplying vendor(s) are less than ideal.
I'd love something where i can p[ut in my VIN and it simply returns the car in parts form and i can go hunting. Back in the day when i was in BMW (i know, sorry :)) there was a site called realOEM that did exactly this however i think that got nuked when the manufacturer eventually had enough evidence and clout to kill it.
This is the page after loggin in where i can buy flatrate service:
We can then see an example of what one of the PDF's might look like; in German for illustration purposes but will come in english, i think...
We have problems with grilles and that’s buying direct from Audi as so many variables depending on spec. I can see a front 360 camera and parking sensors so that would be represented in the part number you need, the black bezel may also change the number again. Best just phoning a dealer and ask for a quote with part number. Shouldn’t be a problem for them
Unfortunately Matt, It’s very rare/ does’t happen, that dealers will give you a part number if you are not actually buying the part from them. Exception might be if the part is obsolete.
