Aliballibee65 Posted April 14 Posted April 14 Evening all, My Audi A5 (35TDI) just passed its MOT with two advisories - one tyre related and one "battery suspect low". The first is easy to rectify but on searching for a replacement battery I've seen a few mentions of having to recode the car to the new battery e.g. "otherwise the alternator will treat it as the old battery"? Previous cars have simply been take old battery out, put new one in. Does the A5 really have to be coded? Is this another trip to the main dealer? Thanks for any assistance.
cliffcoggin Posted April 14 Posted April 14 In a word, yes. The battery does indeed need to be coded to the car. See this for an explanation: https://www.youtube.com/watch?v=IJAScg6JrYI 1
Aliballibee65 Posted April 14 Author Posted April 14 On 4/14/2025 at 9:39 PM, cliffcoggin said: In a word, yes. The battery does indeed need to be coded to the car. See this for an explanation: https://www.youtube.com/watch?v=IJAScg6JrYI Expand Many thanks for the quick response and YouTube clip. Cheers
Magnet Posted April 15 Posted April 15 Hello Alan, I would suggest you get the battery efficiency and alternator output checked before renewing the battery - Halfords stores should be able to do that for you. If it does need replacing, your wallet would appreciate you coming back to us before buying any battery - anywhere. Kind regards, Gareth. 1
spartacus 68 Posted Tuesday at 10:34 PM Posted Tuesday at 10:34 PM Modern cars are very susceptible to energy fluctuation, so a battery on the way out will throw up all sorts of errors, never mind cold cranking amps to turn the engine over. Sometimes it鈥檚 not just starting the car, but the battery under load. As mentioned, it does need coded. Get the best you can afford, likely to be AGM. 1
