This doing my head in.
So I get on my cluster display screen. Active light fault, followed by left and right highbeams faulty. So changed both bulbs with correct bulbs. Put the lights on. Running led lights working. Dipped beams working but still no high beams on both lights and still the same error on cluster screen. Checked all fuses they are fine. Checked the operating stalk that to is working. Weird how both highbeams have gone together. Is there a relay for these lights. If so where is it located? What am I missing? Thanks
Believe it’s a multifunctional relay for main and dipped beam, I would look behind the fuse box on drivers side as relays hidden back there
