Charliie Posted 13 hours ago Posted 13 hours ago I have a6 30l c8 that started dying on me the other day and took it to the garage and they said the battery is not charging on it said it’s the alternator. The car has only got 68000 on it. I was just wondering if anybody else has had this issue. Pls help? Could it be something else? My first error message before it died was⬇️ just sceptical changing it because there like £2000 just for part
cliffcoggin Posted 11 hours ago Posted 11 hours ago 68000 miles is perhaps a little earlier than expected for an alternator to expire, but not unreasonably so. Get the garage to test the battery when you change the alternator as it may have been damaged by continual discharge. However look at another recent topic on this forum regarding "brake servo restricted" for further enlightenment.
Charliie Posted 10 hours ago Author Posted 10 hours ago When the car is running, the batteries only chucking out 12.2 V that’s why I think is the alternator
Magnet Posted 4 hours ago Posted 4 hours ago What is trying to be said here Charlie is that it seems (in caps) that the alternator is at fault, but I would get an independent check on this before taking action. I fully agree with what Cliff is trying to reinforce - don’t assume the battery isn’t sub standard as well - until that has also been tested. If it were mine, I would investigate the route to getting your alternator repaired if found to be faulty. Kind regards, Gareth.
Charliie Posted 4 hours ago Author Posted 4 hours ago Hi i dont think my alternator be repaired as its water cooled has to be a new new one thanks Charlie
Mickwillow Posted 4 hours ago Posted 4 hours ago (edited) I had the brake servo restriction fault not long ago, if the codes the same as mine it’s the pressure sensor near the brake servo! mine was intermittent would go away after turning off and engine the back on ! what other people have said is if fault stays on the ABS pump then takes over braking and that it can get damaged if driven over long distances . By the looks of it in other forums it’s common fault across all Audi’s The pressure sensor is about £94 from Audi parts . Audi changed mine under the all in warranty. Hope this helps also mine seem to throw up the fault when stop start kicked in so I would switch it off straight away after starting the engine . Pressure Sensor 5Q0906207A Edited 3 hours ago by Mickwillow
cliffcoggin Posted 3 hours ago Posted 3 hours ago 39 minutes ago, Charliie said: i dont think my alternator be repaired as its water cooled has to be a new new one Why? A wise man once opined to me that what man has made, man can repair.
