Charliie Posted yesterday at 12:09 PM Posted yesterday at 12:09 PM I have a6 30l c8 that started dying on me the other day and took it to the garage and they said the battery is not charging on it said it’s the alternator. The car has only got 68000 on it. I was just wondering if anybody else has had this issue. Pls help? Could it be something else? My first error message before it died was⬇️ just sceptical changing it because there like £2000 just for part
cliffcoggin Posted yesterday at 02:05 PM Posted yesterday at 02:05 PM 68000 miles is perhaps a little earlier than expected for an alternator to expire, but not unreasonably so. Get the garage to test the battery when you change the alternator as it may have been damaged by continual discharge. However look at another recent topic on this forum regarding "brake servo restricted" for further enlightenment.
Charliie Posted 23 hours ago Author Posted 23 hours ago When the car is running, the batteries only chucking out 12.2 V that’s why I think is the alternator
Magnet Posted 17 hours ago Posted 17 hours ago What is trying to be said here Charlie is that it seems (in caps) that the alternator is at fault, but I would get an independent check on this before taking action. I fully agree with what Cliff is trying to reinforce - don’t assume the battery isn’t sub standard as well - until that has also been tested. If it were mine, I would investigate the route to getting your alternator repaired if found to be faulty. Kind regards, Gareth.
Charliie Posted 17 hours ago Author Posted 17 hours ago Hi i dont think my alternator be repaired as its water cooled has to be a new new one thanks Charlie
Mickwillow Posted 16 hours ago Posted 16 hours ago (edited) I had the brake servo restriction fault not long ago, if the codes the same as mine it’s the pressure sensor near the brake servo! mine was intermittent would go away after turning off and engine the back on ! what other people have said is if fault stays on the ABS pump then takes over braking and that it can get damaged if driven over long distances . By the looks of it in other forums it’s common fault across all Audi’s The pressure sensor is about £94 from Audi parts . Audi changed mine under the all in warranty. Hope this helps also mine seem to throw up the fault when stop start kicked in so I would switch it off straight away after starting the engine . Pressure Sensor 5Q0906207A Edited 16 hours ago by Mickwillow
cliffcoggin Posted 16 hours ago Posted 16 hours ago 39 minutes ago, Charliie said: i dont think my alternator be repaired as its water cooled has to be a new new one Why? A wise man once opined to me that what man has made, man can repair.
Charliie Posted 9 hours ago Author Posted 9 hours ago 6 hours ago, cliffcoggin said: Do u know where i can het it repaired ?
Charliie Posted 4 hours ago Author Posted 4 hours ago 11 hours ago, cliffcoggin said: Tried a few places but had no luck 10 minutes ago, cliffcoggin said:
Optimus Posted 4 minutes ago Posted 4 minutes ago (edited) Its unlikely repairs can be made, a lot of the auxillary engine parts manufacturered to acheive low emiision ratings have become so over complicated that to take it apart and recondition parts the labour to do so is two-thirds of the cost to replace it. Its intentional, car manufacturers are selling less cars today because the cost to make them has gone up. they are recouping reduction of new car sales in parts. This has been going on for the last 3 decades. Google wet timing belts.... which now seem to be going into nearly every vehicle. A rubber belt that deteriotates submerged in oil and carbon based chemicals added with heat alter the structure of the rubber belt overtime/use... They typically last long enough for the warranty to go by but not much longer. Edited 3 minutes ago by Optimus
