Hi.
I have a 2006 ('56) A4 Quattro 3L TDI
I thought I would check the wheel alignment and found that the front wheels toe in, equally, at around 7' and the rear wheel toe in at about 22'. Can anyone tell me what the actual figures should be.
The toe in for the rear wheels seem a lot, but at least the same, and I assume they are fixed and cant be adjusted (??)
Any advice would be welcome.
Thanks
Peter
  • 5 months later...
How did you find out the measurements ?
I presume the cr was on a Hunter Lazer aligment machine or some such, or was it bits of string ?
If a machine then the machine will have all off the OEM settings and the methods of adjustment in the machime memory.
Christ , I forgot some forgot to turn the lights of in this forum when they went home , Or has Audi been found out as its really thier forum! they run it ! I just get sneaky feeling that thats the case
