Benn1e Posted August 29, 2013 Posted August 29, 2013 Hi, Not had a chance to look in the handbook yet as had to work. But I had to take off the battery to top up the water and charge last night, it went back fine and is far better than it was, radio was fine didn't need the code even after 12 hours? but my keyfob won't work with the central locking? is there a simple procedure I can try to sync it again please? hopefully at lunchtime, if not will look it up in the handbook when I am done for the day Cheers Ben
Tech Posted September 8, 2013 Posted September 8, 2013 Put your key in the ignition, hold down one of the buttons and turn the ignition on whilst keeping the button held. After about 10 seconds you can release the button and switch off the ignition, it should then be synchronised
