rachelp Posted November 10, 2013 Posted November 10, 2013 hi when I start my A3 and its below 5 degrees outside I get the temperature warning light on. clearly the vehicle is not running too hot as this is the first use of the day. I've checked the coolant levels and they are at the maximum level so appears this isn't the problem either. This warning light does not come on when the outside temp is about roughly 8 degrees... any ideas?
Audi Owners Club Posted November 11, 2013 Posted November 11, 2013 HI and welcome! Are you sure this is not simply an ice warning when it is below a certain temperature?? Sounds like it is to me
