Hi Guys..
Can anyone assist with this ..
On starting and initial 30 minutes driving..  the passenger heating system works perfectly .. but after that the whole passenger side reverses itself and when I turn the heating to Low it blasts out very hot air from the middle dashboard vent and if I turn it all the way up to Hi max heat it blows cold ???? .. anyone any ideas
Had a similar problem on a Merc that was a temperature sensor
Any help would be appreciated and hope you all have a great New year
The flap motors have been known to go on other Audi models so not sure if this also affects the Q7? Symptoms sound similar? I think it can be a relatively inexpensive fix if this proves to be the problem.
Thanks for the input.. queried it with Audi main dealer and he quoted so many things that it could be but now winter is here it is a case of bite the bullet and just get it done I guess
Thanks again
  • 4 weeks later...
Hi all..
Just to enlarge on the heating problem with my Q7... took it in to the Audi Main Dealer for a diagnostics check.. and yes your correct it is the Flap Motors..
2 of them on the passenger side which are the temperature & air recirculation... Audi are qoting me £90 + VAT which I can easily live with however the sting
comes when Audi need 12 hours to do the job at £120 + vat = £1,728 plus the motors = £1944 so I may as well get all the flap motors done at the same time
just in case another of them go down and I have to dismantle the dashboard again
Now I know some of you might say.. well big car big money serves me right and I agree.. however the point I am making is that this motor only has 80k on the
clock and it has just been in to the same main dealer 3 months ago for 6 new Injectors which cost a fortune ... this isn't quite the Audi experience I expected ..
so i'm defecting.. I've had two X5's in the past and they were faultless so i'm heading back in BMW's direction..
