Hi All,
As one of a lucky few to own a R8, I would like to share my current issue with a serious forum which would offer advice and feedback on the issue below. This is a technicians data report I have received from the on board computer supplying the diagnostics from my R8, I was looking for some feedback on how these fault issues would affect the overall performance of the car in certain situations,and what exactly what are these fault codes exactly! or indeed if anyone else has had these kind of issues with their R8. what work would be required to actually check these faults on the car, and would anything need to be taken off the car to check? be great to know.
Many thanks
R8 Owner :mellow:
004.01 - Check Event memory
Function successfully performed
1 Malfunction detected
01316 013
Brake control module
Please read DTC
Intermittent
00778 008
Steering angle sensor
Implausible signal
Intermittent
01316 013
Please read DTC
Intermittent
Priority: 2
Malfunction frequency counter: 1
Unlearning counter/driving cycle: 26
Time indication bit: 0
Measured values:
13.9 V
30 km/h
5.0 V
03 - Brake electronics Yes can be reached Error Drivetrain CAN 0010
14 - Wheel insulation electronics Yes can be reached Error Drivetrain CAN 0010
16 - Steering column electronics Yes can be reached Error Comfort CAN 0010
