Tufnnuf Posted February 3, 2014 Posted February 3, 2014 Hi All, As one of a lucky few to own a R8, I would like to share my current issue with a serious forum which would offer advice and feedback on the issue below. This is a technicians data report I have received from the on board computer supplying the diagnostics from my R8, I was looking for some feedback on how these fault issues would affect the overall performance of the car in certain situations,and what exactly what are these fault codes exactly! or indeed if anyone else has had these kind of issues with their R8. what work would be required to actually check these faults on the car, and would anything need to be taken off the car to check? be great to know. Many thanks R8 Owner 004.01 - Check Event memory Function successfully performed 1 Malfunction detected 01316 013 Brake control module Please read DTC Intermittent 004.01 - Check Event memory Function successfully performed 1 Malfunction detected 00778 008 Steering angle sensor Implausible signal Intermittent 004.01 - Check Event memory Function successfully performed 1 Malfunction detected 01316 013 Brake control module Please read DTC Intermittent Priority: 2 Malfunction frequency counter: 1 Unlearning counter/driving cycle: 26 Time indication bit: 0 Measured values: 13.9 V 30 km/h 5.0 V 03 - Brake electronics Yes can be reached Error Drivetrain CAN 0010 14 - Wheel insulation electronics Yes can be reached Error Drivetrain CAN 0010 16 - Steering column electronics Yes can be reached Error Comfort CAN 0010
