Hi
I'm having trouble removing the wires , from the rear of the light unit , so that I can slide the unit out to change a blown dip headlight bulb on the drivers side if my Q7.
Any ideas to how this is done , as it seems to be held in somehow ??
Looked through some other Audi forums , and found out how to remove wire fitting.
For those , like me , that didn't already know , you push the fitting onward while pushing on the square shaped bit on its side and then while still pushing on the square shaped part , pull it off .
Yea , I'll do that . I want to upgrade the headlight bulbs to ones that are brighter , so I could do that then.
Sounds good. What bulbs are you thinking of using?
