Hi all,
I'm wondering whether you could help me. I've recently purchased a 57plate S3 that has bluetooth so i can connect my iphone. I've done this without any issue however the problem that i appear to be having is that whilst using the phone the functions on the sterring wheel appear to be disabled.
Whilst i'm listening to the radio/CDs the functions on the wheel are fine so I can change stations and volume levels etc. However the mode and voiceactivitation buttoms appear to be disabled as well.
Is there a setting somewhere that dis ables the multi function steering wheel whilst the phone is active? It just seems strange that the volume adjusting button works for the radio/CDs but not when I'm on the phone.
Thanks for your comments in advance.
Si
Hi, yes everything is factory fitted. The only thing modified from the origianl (i think) is the introduction of an ipod cable instead of the CD multi changer.
It's part of the audi Sat Nav if that helps further
would reprogramming require a garage?
I've tried de pairing and pairing the iphone several times with no change
Yes I would imagine it would require someone with the relevant Audi software and cable. When you're on the phone does the volume adjust with the control on radio?
Yes - i can adjust the volume of the phone conversation using the control on the radio but nothing using the steering wheel
If I were you I'd contact your local audi dealer I have the same problem and I later found out I've the buttons but it wasn't installed at the factory so they are for show unless I get it fitted
