norwichdaz Posted February 22, 2014 Posted February 22, 2014 hi new user here... I have a 1998 1.8T a3 with original radio etc and I THOUGHT it would be just a easy case of take out put the normal 2 blocks in and aerial but no ... so I had to get a different iso adapter... to put in my newer cd player... however it still left me with a single brown (earth wire) so im guessin I need to earth that sumwhere ? or has the new adapter plugs got an earth ? as it worked when I 1st connected it bit went to push it in to the slot and then it stopped working but also the power block into the head unit isn't all that amazing fit but if I pull it back out and hold it in it still doesn't turn on so guessin might have blown a fuse or killed the head unit ?? im pro going to go and buy a new head unit this weekend... any ideas ? thanks..... the pic doesn't show the earth single wire which was slid onto the back of the old original... I just didn't want to buy a new one and potentially blow another unit (if that's what has happened) 1
Audi Owners Club Posted February 26, 2014 Posted February 26, 2014 Hi Daz, If it worked originally it will more than likely be a loose connection where you have pushed it in and it was quite tight. Could have popped something out so I would check this first. If it was the earth that wasn't connected it wouldn't have turned on at all. 1
norwichdaz Posted February 28, 2014 Author Posted February 28, 2014 ok will give it another go tomoz I have bought a new adapter for it now so all fits ok..... just that the black block I guess isn't THAT tight in there now even if I hold it in .... so im not sure whats up really ..
