hi guys new on here and I think I'm in trouble! as above the dreaded light has come on, any possible causes? done the obvious and checked the oil and water but I'm now afraid to drive it to a garage for a diagnostic check.any suggestions will be much appreciated!
  • 1 month later...
Hi, which light has come on your dash?
Buy yourself a Fault code reader (no need to spend any more than £30) this should be able to tell you down to the offending part what's wrong! Very good investment...
