steve snr Posted August 21, 2014 Posted August 21, 2014 hi all my 57 plate q7 rear panroof stays open about 10 millimeters can any one help to solve my problem helppppppppppppppppppppp
Chrismcg Posted August 26, 2017 Posted August 26, 2017 On 21/08/2014 at 8:33 PM, steve snr said: hi all my 57 plate q7 rear panroof stays open about 10 millimeters can any one help to solve my problem helppppppppppppppppppppp Hi. I have the same issue. Did you get this sorted?
Bigdave1230 Posted August 27, 2017 Posted August 27, 2017 My rear panel won't open at all and hasn't done since I've owned it. Apparently they seize up. Try closing the rear sun visor and then closing as the sun visor clip can go back too far when open and put too much resistance on the sun roof so won't close. Failing that there is a panel on the passenger side of the dash board when the door is open that comes off and exposes some fuses but on the back of that panel there is a special shaped Allen key. Pull the interior light down behind the sunroof to expose the motor. There is a really obvious hole the key goes in where you can manually wind the roof back in. Hope this helps Sorry can't post a picture it says max total size 0.24mb 🤷🏻♂️
