Hi,
I have an Audi A6 late 2009 model, the MMI system keeps freezing. some times it will reset straight away but other times may be several days this can happen 10 -15 per trip then not again for weeks. There seems to be no common reason for it to happen. Is this a common problem and if so is there a solution to it?
  • 1 month later...
My 2009 Q5 has a similar problem. I have an intermittent problem selecting a media sourcein the MMI I.e. at present I get a perpetual 'loading' message for all media sources, jukebox, CD, SD cards. This started with the jukebox access and lasted a few days after which the jukebox HD was accessible again. The most recent form of the problem affects all sources. I can see the contents in each case but cannot load/play any track. Radio and navigation are ok. Anyone have any advice?
