Hi Guys my 1st post! Im 2 weeks into ownership of my A6 saloon 3.0tdi quattro and can't enjoy it due to numerous issues. Its 2008 90,000 mile fsh. On sat i had a rear fog warning light on drivers side so checked it and it was fine, moments later rear brake light failure and this was the whole led strip (irreplaceable) now today i have the indicator blinking fast on the same side (driver) . Sounds like the electrics are up the shoot but i want to throw it back to the dealer at the moment. Thanks in advance Luke
Hi , I also had issues with the rear lights on my Le Man. Easy fix though, just solder an extra earth wire to the "circuit board" type thing the bulbs fit into. Locate the brown earth wire on the upcircuit of the multiplug and tap into it. You'll need to make a small hole for the wire to pass through but I did this with the hot tip of the soldering iron.
Hope this helps!
