jenifernan Posted December 19, 2014 Share Posted December 19, 2014 Use the car for a long time, theinterior part will inevitably encounter some damage, replace all? Someoverkill; not bother? Not only affects the visual appearance, but also reduceyour driving pleasure. Knowledge T139 modification period Xiaobian take youlook at the contents renovated knowledge, we first look at the original seat ofrepair: FAQ: leather dirty, damaged, smoke hole If that body paint gives a beautifulvisual experience or not, that the people closer to the interior lay out, theimpact will be felt more directly in the mood, the shabby interior renovation,changing driving environment is not just a new look, and allow each of controlhave a good mood. The first to introduce the repair onthe seat, the seat will be damaged reason, common problem is friction or sweatdipping, resulting in damage to the leather, we can not overlook the power ofsweat in Daren years of experience in the renovation, and breakage of the loweredge of the seat thigh regular contact, but fairly common problem, it is recommendedthat owners exercise habits, exercise is best to shop on the car Auto Performance Parts after a dry towel in the chair surface, reducing the seatbuildup of sweat opportunity; in addition, accidentally fell into the seatsoot, smoke hole is caused by a common seat breakage problems. The seat breakage problems, the mostcommon cause in addition to smoke outside, wear, friction and sweat is causedby dipping, especially after the latter for sports wear shorts, the owner of avehicle driving in the car immediately is particularly common, preventable themethod can spread a towel on chairs to face. In addition to damage to the seat, theone inside the foam collapse is the focus of the renovation project, therenovation of the way the seat to be first removed, and then the collapse ofpart of the re-use of foam shaping, in order to restore the original height andflexibility, and Daren while making foam update fixes usually can ride againstthe owners of the body and used to carry out modifications foam height andsupport position Shock Absorbers, allowing owners to enjoy the new look of the interior, butalso can have a more comfortable ride feel, be modified to serve multiple ways,and the new foam used are imported from high-density foam, do not have to worryabout durability. Quote Link to comment Share on other sites More sharing options...
