Hi folks , I have a drivers side rear door speaker needing replaced on my '08 q7 .
I needing some help on how to remove the door panel so I can change the speaker .
Thanks in advance!
Hi James, IIRC the door card has four torx screws to remove - 2 behind the door pull, 1 behind the wood trim and 1 at the bottom of the door in the centre.
Does that seem to tally up with what you have?
Thanks.
I can see the one at the bottom center of the door, but there is none at door release handle.
I'm not 100% sure but I think there may be a cover over the door pull that you pull off and the screws are under there?
Yes, I found a photo that someone added to a thread about this on another forum.
You have to remove the handle face to access 2 screws and the Silver / wooden strip at the top for a screw close to the door opening lever. The other one is at the very bottom of the door.
Thanks for your help!
No problem, glad I could help!  :)
Has the speaker just gone faulty or are you upgrading?
Just a note to anyone else attempting to do this.
Prise the door pull handle cover off from the bottom first, and the door strip off from the right hand side first(left hand side for left door) .
Thanks James glad you managed to get it sorted  B)
