periklis_sale Posted August 10, 2015 Share Posted August 10, 2015 hi guys i was wonderign if i can use my Karcher K4 Compact Home Pressure Washer 130 Bar to wash my Audi? is it safe? thanks Quote Link to comment Share on other sites More sharing options...
James Posted August 13, 2015 Share Posted August 13, 2015 I believe the K4 comes with a variable pressure lance so you can always turn it down to be safe? If you look at that model on Amazon is clearly shows it being used on a car so I assume it will be fine. As with all pressure washers just use common sense and don't get too close to the car. Also, spraying at an angle helps too. Quote Link to comment Share on other sites More sharing options...
