msuth92 Posted October 15, 2015 Posted October 15, 2015 So I've read that forte turbo cleaner can clean the turbo veins in a TDI would it work on my a3 2.0 TDI 8p because when I've researched it all that comes up is for a bunch of Toyota engines ????
James Posted October 16, 2015 Posted October 16, 2015 I'd say any of these cleaners are worth a go as if they do work then it's a cheap fix. Also try running a couple of tanks of premium diesel like Shell V Power Diesel or similar...
msuth92 Posted October 25, 2015 Author Posted October 25, 2015 Okay so I've been running premium diesel and I've used to bottles of forte I've done 54 miles I've rev'd my engine till to 5000 rpm and there's black fumes coming out. Before I used the cleaner I did Rev the engine and it was just white so I can only assume that the cleaner is working and the black stuff coming out is the rubbish that's been stuck on my turbo vanes ?? Anyway will keep posting to see if it works
James Posted October 26, 2015 Posted October 26, 2015 Okay so I've been running premium diesel and I've used to bottles of forte I've done 54 miles I've rev'd my engine till to 5000 rpm and there's black fumes coming out. Before I used the cleaner I did Rev the engine and it was just white so I can only assume that the cleaner is working and the black stuff coming out is the rubbish that's been stuck on my turbo vanes ?? Anyway will keep posting to see if it works Sounds like something definitely needed a clean then! :P
