Arronbill10 Posted November 5, 2015 Posted November 5, 2015 Hi my poorly s3 has gathered a problem Started juddering and misfiring below 2000 revs and idle. Plugged into vagcom no fault codes except intermittent misfire. Dug further cylinder 2 keeps misfiring changed the coil pack no change, new spark plugs no change, cleaned injectors and moved no2 to 4 and still misfire cylinder 2 checked injector 2 wiring all is well so I have drawn a blank any helpers thanks
James Posted November 6, 2015 Posted November 6, 2015 Not sure if yours still has the ignition amplifier if so it could be that. Also, I've even seen reports before of misfires caused by boost pipes that have become disconnected.
Arronbill10 Posted November 8, 2015 Author Posted November 8, 2015 Thanks I will trace all boost pipes for leaks. Mine doesn't have the ignition amplifier.
Arronbill10 Posted November 9, 2015 Author Posted November 9, 2015 Have no leaks on boost pipes but I did notice the wiring to the egt sensor has snapped. But from what I can see on the turbo it looks like it has been blanked ? Confused
James Posted November 10, 2015 Posted November 10, 2015 Hmmm I must say I'm pretty stumped it sounds like you have tried everything obvious!
