So this weekend just passed i finally picked up my Mk2 TT -
2.0TDI Quattro
Bose Sound system
Auto Lights
Grey / Green - (Unsure of what its called)
18" Wheels
Single Disk CD Player
Folding Mirrors + Heated
12546133_10153435722496733_965386215_o.j
12591887_10153435744876733_904962342_o.j
As my father already has a TT Quattro 2.0 TDI S-Line Black it made me want one..
Fathers...
12620513_10153435743996733_1263385999_o.
Found one very cheap but had a couple of issues with it that i knew about and needed to get fixed but for what i paid i cant complain.
Issues
DPF Blocked
SunVisor Broken
Rear ParcelShelf Needs fixing
Glove Box Broken
Passenger window switch not working
Rear Speakers not working
12511273_10153435722536733_638509352_o.j
So the plan
Remove DPF / Clean Out and Clear
Remap
Refurb Wheels + Change Colour
TTRS Front Bumper + Splitter in Orange
Underside of Spoiler Painted Orange
All Grills Painted Black
Remove all Rear Badges
FIt Private Plate + Shrinked Plate on rear
Rear TTRS Valance
TTRS Look Rear Exhausts + 2.5" System
Lower 20-30mm on springs
Cruise Control Fitting
Bluetooth Audio Stream
Tint Rear Windows
Paint Calipers
Good Service + Maintenance
Stage 1 Clutch
Bigger Intercooler
Improve Breathing to the engine ( Air Filter )
Bigger Calipers + Disks (Potentially TTRS)
Sat Nav System / 6 Disk Bose Audi System
1. So one day after i picked her up i had a guy i know from previous remaps come round and get the DPF issue looked at and a tidy Quantum Remap put on the car to boost what it currently stands at...
Modern Remapping who with TerraClean headed down to sort Smokey out...
12562379_10153435747616733_628651917_o.j
First The Guys had to drop the Subframe down to get to the DPF ...
12591981_10153435722336733_705984876_o.j
12545819_10153435722261733_1257895751_o.
Standard for me there was one bolt that wouldnt come off no matter what, so it all went back on and we did a clean though instead as there was no Ash build up and only 50% block so worked perfectly.
12620608_10153435722226733_1028754222_o.
Turns out it needed a Boost Sensor so also purchased that and fitted ( No Pics )
New Issue
So now we have the DPF Clear and the new Boost sensor the car is popping up with a new fault code:
"B" Rocker Arm Actuator Control Circuit Low
Code : P2653
This is the next task, she drives fine and pulls well but this has the coil and Engine management light up so waiting to head to AUDI to get their kit on it and see.
Has anyone had this issue before? If so would love some advice.
In Total great weekend, new car and shes now Mapped to 205bhp and 400lb Torque Clutch is slipping when you boot it in 4th, 5th and 6th so going to take it easy because of the torque.
Thanks for reading and will keep updates coming as i go.
Elliott
HI Elliot, welcome :smile:
Sounds like you have a few issues there but at least you picked up a bargain so all is good!
Are you planning on changing out the clutch to deal with the slippage?
Hi Mate
Yes already looking at a Stage 1 clutch, will be helpful when i have a new bigger turbo, intercooler and breathing sorted on it. Doubt it will deal with 550-600lb of Torque haa
I'm sure that will be a bit of a beast when it's done. You should start a build thread to keep a track of your progress!
