Hi everyone.
After living with the car for a couple of weeks now you notice things that need doing!
Now I knew there was something up with the front soft close on both sides. My question is are they on a fuse/relay or when they stop is it a dead motor generally? There is no noise at all when the door just clicks in. If it is a dead motor is it a separate unit to the actual door lock itself?
Also the exterior door handle lights. Should there be 2 lights under each handle? As I only have 1 on 3 handles and the drivers door no light at all.
On my dad's 2010 S8 he has 2 per handle.
I have plugged in my vcds but can't seem to find anything on either of these problems. I admit I'm not fully 100% with vcds yet but am learning!
And lastly for now! The main headlights are to low, are they only adjustable through vcds?
Thanks for reading
Ricky.
I think the soft close is a bit of a common problem on the A8/S8 and can be a snapped cable rather than a motor or anything.
Not sure on the number of lights under each handle - is it not possible to see the individual bulbs using a mirror?
