Dale Posted March 15, 2016 Posted March 15, 2016 Hi, my names Dale and I'm new to this forum. I need a drivers side rear light cluster for my 2004 A3 TDI 1.9 sport, just the bulb holder not the lens cover. I was quoted £50 from an online breakers yard search engine, seems a bit steep for a second hand bit of plastic. Anyone know of a breakers or whatever where I'll be able to get a second hand rear light cluster at a decent price. I did buy one for £5 off a guy on eBay but its gone missing in the post, !Removed! typical.
James Posted March 16, 2016 Posted March 16, 2016 Hi Dale, have you tried using a site such as 247 spares where the various scrap yards quote you? Other than that I was going to suggest being patient with eBay or whatever?
Dale Posted March 25, 2016 Author Posted March 25, 2016 Hi James, yes I've done that but their quotes are no lower than most of those on eBay and amazon circa £45 - £50. Luckily I've managed to get two second hand ones on ebay for only £5:00. Unfortunately however, it seems to be a wiring problem not corrosion of the unit as I was told it was from a mechanic. A different mechanic has had a look and believes this sort of problem can be a fault on VW's and Audi's. The easiest fix seems to be to run a feed from the opposite rear lights wiring which is what I'm going to do. Has anyone else had rear light failure be it the break or reverse lights and if so what was the diagnosis and how was it remedied. Thanks, Dale.
James Posted March 30, 2016 Posted March 30, 2016 Is it just one light that isn't working or the whole cluster?
Dale Posted March 30, 2016 Author Posted March 30, 2016 Hi James, all fixed now mate but thanks for asking. It was the os reverse and break lights, obviously it wasn't the bulbs as that was the first thing checked. Now that I'm on here do you know anywhere that I can get an os rear break caliper, I need the full caliper, a repair kit is no good as mine is too far gone, that's according to my mechanic whos also a good friend so he's not pulling a fast one. He's trawled the local breakers today (around the Newcastle area) and all suitable Audi's have been stripped. He's going to check the part numbers because he thinks a ford galaxy or a vw sharan may fit. If you know anywhere else though that's cheaper than whats on ebay please do let me know. Thanks.
Dale Posted March 31, 2016 Author Posted March 31, 2016 Anything from about £40 upwards. There are cheaper ones on eBay but they all seem to be calipers for the rear near side and not the rear offside which is what's required. I'll keep looking, MOT is not until June however if you know of anything I'd be happy to hear from you. I'm on a tight budget as I've had to quit work through ill health. Cheers James.
James Posted April 5, 2016 Posted April 5, 2016 £40 doesn't seem that bad to be honest for a full calliper. You might find something cheaper but I wouldn't think by much.
Dale Posted April 5, 2016 Author Posted April 5, 2016 Hi James, I bought a new one for £40 on eBay, it came today and I'm happy enough because after further research they can be going for £50 plus for a new one.
James Posted April 6, 2016 Posted April 6, 2016 That's good Dale, doesn't sound bad really. Hopefully you can get back to enjoying your Audi once that is fitted!
