Q7phantom Posted March 30, 2016 Posted March 30, 2016 Hi, I have a problem with the drivers side electric seat on my car, it seems it has no power going to it.. It works when I attach a wire to an empty fuse in the fuse box and directly to the switch so I know it is not the motor.. does anyone where the problem could be? Is there a fuse for the seats, if so is it a different one for each seat as the passenger on is working fine? If not fuse do you think it might be a relay.. Can anyone recommend a decent pc manual for the q7 that will have all possible solutions for the seat problem.. Any help would be appreciated as I'm having to drive with my head almost touching the windscreen!!
Q7phantom Posted March 31, 2016 Author Posted March 31, 2016 It's a 2006 model, problem only started this year, when I had some water in the footwell.. I'm guessing it may have fried the ccm, but everything else is working fine apart from seat..
Q7phantom Posted March 31, 2016 Author Posted March 31, 2016 Checked all the fuses in the drivers side of the dash, they seem fine.. I know there are fuses on the the passenger side and in the boot and probly under the bonnet aswell.. I hope it's just a simple fix as dealers want a stupid amount just to diagnose.. I have vcds but no errors showing other than a something to do with inlet manifold which I'm certain has nothing to with seat..
James Posted April 5, 2016 Posted April 5, 2016 I think there is a module for each seat so it could be that if the motors are ok?
Q7phantom Posted April 13, 2016 Author Posted April 13, 2016 Thanks for the reply.. Got it sorted finally. Power wire under the seat had broke!!
James Posted April 14, 2016 Posted April 14, 2016 On 4/13/2016 at 10:14 PM, Q7phantom said: Thanks for the reply.. Got it sorted finally. Power wire under the seat had broke!! Expand Turned out to be something simple in the end then! Glad you got it sorted
