Rsorted Posted April 20, 2016 Posted April 20, 2016 Hi everyone. I'm praying some of you knowledgable lads can help me with my water loss. one of my friends recommended this site and said yous know more about our A4's than Audi lol. so here's the problem..... Started loosing water months ago. Turned from a litre-litre and a half every six weeks to a slow graduation of that amount every month and now I've clocked a hundred mile and the water needed topping back up from minimum. So I've had it in a decent reputable local garage all week as my friends a mechanic and he's pottered on checking everything and pressure testing it etc and can't find any apparent external or internal leak? 😐 with that said... He had to clear the drains in the bulkhead and drain it as it was holding a few litres of standing rainwater due to the drains being blocked. Although this is presumed to be rainwater. There wasn't any antifreeze in the car anyway to check as I've had to top it up so much. The cars recently had a new water pump 10k ago with its timing belt kit all genuine parts. Full Audi history and 180k. 2.0tdi Quattro 170 07 B7 if anyone's got any suggestions or ideas then I'm all ears. Any constructive input would be greatly appreciated !
Brucielee Posted April 20, 2016 Posted April 20, 2016 I take it there's no puddles on the under tray either, You say the waterpump had been done not that long ago, I would maybe get that checked, as it's behind the plastic cover over the timing belt you wouldn't see if water was coming from there or not, Than again I was losing coolant from a stress crack underneath the expansion tank which I couldn't see,
Rsorted Posted April 20, 2016 Author Posted April 20, 2016 12 hours ago, Rsorted said: Thanks, I am actually gonna change the expansion tank with coolant level sensor as the sensor has stopped working to tell me the level is low. will let you know when I get it off. Cheers. any more ideas is much appreciated
