Bipman Posted April 20, 2016 Posted April 20, 2016 Hi all I think my aircon re-circulation actuator is a bit stuck as the aircon only seems to work properly in re-circulation mode. Is this actuator easy to reach or would it need a garage to check it ? It's a 2008 2.7TDi model. Bipman
James Posted April 20, 2016 Posted April 20, 2016 Do the fans work (with air con off) while in normal non recirculation mode?
Bipman Posted April 20, 2016 Author Posted April 20, 2016 I'm not sure; do you mean in Eco mode ? Bipman
Bipman Posted April 20, 2016 Author Posted April 20, 2016 Hi I've scanned the codes and get the following for the Aircon Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q Component: KLIMABETAETIGUNGH30 0020 Revision: 00000052 Serial number: 00000000471089 Coding: 0001302 Shop #: WSC 02325 758 00200 VCID: 1C304C5FDFB860DEA1-8048 1 Fault Found: 01274 - Air Flow Flap Positioning Motor (V71) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 254 Reset counter: 115 Mileage: 131582 km Time Indication: 0 Date: 2015.05.01 Time: 20:54:43 Freeze Frame: Voltage: 13.10 V Temperature: 22.0°C (no units): 160.0 (no units): 165.0 Temperature: 9.0°C Is this motor east to get to ? Bipman
James Posted April 21, 2016 Posted April 21, 2016 At least you know what it is now... Doesn't sound that easy though - see this from a VW forum: http://forums.vwvortex.com/showthread.php?5499264-01274-Air-Flow-Flap-Positioning-Motor-(V71)-014-Defective
Bipman Posted April 21, 2016 Author Posted April 21, 2016 I took a look on ElsaWin and it looks like you only have to remove the windscreen wiper arms and then a few bolts. I believe the wiper arms are a bit of a pig to remove though. Bipman
James Posted April 25, 2016 Posted April 25, 2016 On 4/21/2016 at 1:19 PM, Bipman said: I took a look on ElsaWin and it looks like you only have to remove the windscreen wiper arms and then a few bolts. I believe the wiper arms are a bit of a pig to remove though. Bipman Expand Are you planning on giving it a go soon then?
Bipman Posted April 25, 2016 Author Posted April 25, 2016 Maybe. Weekends are too busy at the moment but I'll take a look and see if it looks relatively easy. The main issue will be removing the wiper arms if they are locked or need a puller.
Salter Posted June 25, 2023 Posted June 25, 2023 Hi I’m new on here and I e just got a Audi s4 b9 2017 I’ve got problem with the Recirculation flat motor under the glove box and I can’t seem to find which motor it is as found there is about 5 of them down there any one know which one it is be much appreciated
