Hi, sometimes when changing gears and releasing the clutch there's a loud squeek, it doesn't happen all the time and is mainly in the lower gears also when reversing uphill for example and in higher revs there's a clunk then a weird noise? Like a wurring sound but then disappears when the cars put into 1st gear and doesn't make the sound or clunk when reversing on the flat. I'm just wondering if anyone has any ideas?
Many thanks
Dan
Could be the clutch release bearing causing the squeak Dan?
