Denispearl Posted May 1, 2016 Posted May 1, 2016 Greeting to all. Hope you all well. I have recently developed strange issue with a rear light , as per picture. Just noticed today that 2 sectors on the rear read light , right side are constantly on, despite the fact that brakes arent engaged. What could that be? Ddn't do anything to the car, apart of puting it through the hand wash today and polishing/waxing later. Thanks a ton for your input in advance.
Brucielee Posted May 1, 2016 Posted May 1, 2016 How's things and hello to you, welcome to the club First thing I'd check is the switch behind the brake pedal, make sure it's not stuck on, if it is its fairley cheap and easy to fix
Denispearl Posted May 3, 2016 Author Posted May 3, 2016 Hello all. thanks for the all input. Unfortunately the fog light is off Many thanks
Denispearl Posted May 3, 2016 Author Posted May 3, 2016 On 5/1/2016 at 10:48 PM, Brucielee said: How's things and hello to you, welcome to the club First thing I'd check is the switch behind the brake pedal, make sure it's not stuck on, if it is its fairley cheap and easy to fix Expand I cannot check the switch as couldn't find. Could you please advice if possible on where is it located ? Thank you kindly
Brucielee Posted May 3, 2016 Posted May 3, 2016 You need to get up behind the brake pedal to reach it, probably best taking of the plastic trim that is below the steering column to see it clearly, Pull the brake pedal towards you and have someone watch the lights to see if they go out or not, just out of curiosity
James Posted May 25, 2016 Posted May 25, 2016 On 5/25/2016 at 8:17 AM, Denispearl said: all sorted. Simple bulbs change Expand Love it when you get a nice and simple result!
